Discovery 2 Towing Advice
Old Jul 28, 2011 | 02:10 PM
  #21
souljad9's Avatar
Originally Posted by gigharbori
Also read this on Weight Distributing Hitches…..
HowStuffWorks "How Towing Weight Distribution Systems Work"
Can't use a weight distributing system on a trailer with surge brakes. if he has the 4pin towing harness, all he needs to do is buy a 4-5pin adapter, and tap the extra wire to his reverse lights, to trigger the lockout solenoid. As for tongue weight, you can adjust where the boat sits on the trailer to adjust the tongue weight. Load farther behind the axles = less tongue weight.
Old Jul 28, 2011 | 10:48 PM
  #22
mwindth's Avatar
Originally Posted by fiorano
Just to give you a heads up, I imported my D2 from the States because of the better spec and better engine.
WOW, I never thought I would read that statement on this forum...they were all made in the UK, not a "better spec" because you imported from the US...and IMO, the TD5 is a MUCH better engine...again, IMO.
Old Jul 29, 2011 | 08:47 AM
  #23
jafir's Avatar
I think he was just talking about the V8. I think you could only get the 4.6L in the North America Spec disco.
Old Jul 29, 2011 | 08:58 AM
  #24
boxerboy2's Avatar
Default Your crazy!
Other than moving the boat around a yard, I think you are ...king nuts!
I have a 26 foot Regulator that probally comes in around 8,000+ lbs, (twins, 215 gal of gas x 6.5 lbs, gear) and I tow it with an F250 that is rated to tow 10,000 and it takes all of that to tow it around town or down the highway. My F250 is a monster of a truck and it really works pulling the Regulator, I could not imangine moving down the road with it behind a DII, again ... around the yard ok but not down the road.
I do move the empty trailer with the DII and thats no problem!
Good luck and please post a photo!
Old Jul 29, 2011 | 08:02 PM
  #25
Only in the NAS was the 4.6L engine offered, everywhere else either had the 3.9 petrol, the TD5 or the MPI (4 cylinder OHC)
Old Jul 29, 2011 | 08:26 PM
  #26
mwindth's Avatar
Thanks Spike and jafir for clarifying...I still can't imagine though someone choosing a petrol over a TD5, especially for towing, but I guess it is all relative.
Old Jul 29, 2011 | 09:14 PM
  #27
Maybe he cant get a TD5 in the UAE.
TripleThreat
Apr 6, 2014 10:42 PM
Second2None
Sep 25, 2011 09:32 AM
blcp86
Jul 14, 2011 08:15 PM
bradb
Jul 8, 2007 08:28 AM
RobFrey1
Oct 14, 2005 12:14 PM
