Discovery II 2003 traction control issue
Old Mar 25, 2019 | 02:56 PM
Billfromthehill's Avatar
Do you see you tc indicator light up when wheels spin is present? Any time wheel slip is detected the tc light will light up and you can hear the abs pump go to work. If not then your tc isn’t functioning.
Old Mar 25, 2019 | 10:47 PM
Stein's Avatar
The TC reacts once one or more wheels have already lost traction. You lose some forward momentum as the TC starts working which can cause the truck to get stuck cause now its just digging down deeper into the low traction surface while braking the spinning wheels.
The CDL proactively helps to keep the truck moving as long as 2 wheels on the same axle have traction. You dont lose forward momentum which helps maintain rolling traction.
Old Mar 26, 2019 | 09:04 AM
jastutte's Avatar
^^this^^
Old Mar 26, 2019 | 09:24 AM
GCBurke's Avatar
I see some use the ebrake at times to help gain traction....does this just cause redistribution of power to the front?
Old Mar 26, 2019 | 10:40 AM
Richard Gallant's Avatar
One thing about the TC system in the Discovery is your brakes need to be in good working order, so weak pedal, worn pads will all impact it. And 3 amigos it does not work at all.
Old Mar 26, 2019 | 12:29 PM
mollusc's Avatar
the e-brake on the disco works on the rear output from the transfer case. my guess would be that using it with an unlocked t-case would force power output to the front wheels. if it's the front wheels that are spinning, it's not going to help anything.
Mr. Tick
Dec 9, 2017 11:07 PM
fern540
Feb 14, 2013 03:38 PM
pclloyd
Mar 30, 2010 04:26 PM
catchmyktm
Jun 5, 2008 02:16 PM
catchmyktm
Jun 5, 2008 10:59 AM
