Discovery II, which engine?
I went to Autozone to pick up some spark plugs for my 2002 Land Rover Discovery II SE and found that I had two engine types to choose from:
8 Cylinders 2 4.0L MFI OHV
or
8 Cylinders 5 4.0L MFI
and I had no idea which mine was. I went with the first one (OHV) and got some NGK platinum plugs.
http://www.autozone.com/autozone/par...er=505372_0_0_
Did I get the right ones or not? I need to know because I'm going to have them installed tomorrow morning. How do I find out which engine my Discovery is?
Thanks.
or
Thanks.
http://www.roverparts.com/TechTips/a...tionengine.cfm
Your 2 engines are a LEV and non LEV.
If you have the engine in the link above then you have the LEV engine.
Low
Emission
Vehicle
Low
Emission
Vehicle
Hey wizdom...just an observation...those look like the original OEM wires in your pics...as long as you are replacing the plugs (if it were me), I would also replace the wires with Magnecor, STI or Kingsborne 8mm...if they are original, it is about time to replace.
tcbinaflash
01-08-2008 04:23 PM
