Discovery II, which engine?
Old Nov 8, 2010 | 08:13 PM
wizdom's Avatar
Default Discovery II, which engine?
I went to Autozone to pick up some spark plugs for my 2002 Land Rover Discovery II SE and found that I had two engine types to choose from:
8 Cylinders 2 4.0L MFI OHV
or
8 Cylinders 5 4.0L MFI
and I had no idea which mine was. I went with the first one (OHV) and got some NGK platinum plugs.
http://www.autozone.com/autozone/par...er=505372_0_0_
Did I get the right ones or not? I need to know because I'm going to have them installed tomorrow morning. How do I find out which engine my Discovery is?
Thanks.
Old Nov 8, 2010 | 08:33 PM
http://www.roverparts.com/TechTips/a...tionengine.cfm
Your 2 engines are a LEV and non LEV.
If you have the engine in the link above then you have the LEV engine.
Low
Emission
Vehicle
Old Nov 8, 2010 | 09:06 PM
wizdom's Avatar
I think I do have the one mentioned above. Here are two pictures from each side of my engine:
Old Nov 8, 2010 | 09:17 PM
mwindth's Avatar
Hey wizdom...just an observation...those look like the original OEM wires in your pics...as long as you are replacing the plugs (if it were me), I would also replace the wires with Magnecor, STI or Kingsborne 8mm...if they are original, it is about time to replace.
Old Nov 8, 2010 | 09:33 PM
wizdom's Avatar
Yep, I bought the parts already. Got a new ignition coil (it was acting up), 8mm Kingsborne, and NGK platinum plugs
Old Nov 9, 2010 | 06:04 PM
Yes you have SAI (secondary air injection), thats what those round thingy's are, air pumps to force fresh air into your exhaust to help the catalytic converters get to temp faster.
Think of them as a blacksmiths bellows.
Old Nov 10, 2010 | 08:17 AM
How do you know your coil was acting up, what fault code numbers did you get? I wouldn't install it on just a guess, kinda of a waste of money.
Old Nov 10, 2010 | 12:44 PM
wizdom's Avatar
Well the mechanic told me it was acting up. I wasn't completely convinced. Nevertheless, I bought all the parts and he installed them yesterday. Everything seems to be working fine now.
I don't remember the exact codes. In retrospect, I should have written them down.
HopeItsNotAMoneyPit
Jan 15, 2015 11:28 PM
salve7
Mar 9, 2010 06:06 PM
AK Rover
Mar 20, 2009 09:51 PM
duckprefect
Freelander
Mar 9, 2009 08:27 AM
tcbinaflash
Jan 8, 2008 04:23 PM
