Discovery II Head Gaskets -- Not OEM
Old Apr 6, 2018 | 09:33 AM
Psycho_Taco's Avatar
Originally Posted by CollieRover
The term hand tight, does that mean just get it in until it stops or to use a socket and had tighten it as hard as I can?
I am also going to clean the rest of the bolt holes, and got new bolts for the lower intake as well. Should I soak those in oil?
When do you use threadlocker?
When we did mine we interpreted hand-tight as just that, no socket or wrench. The ARP instructions specify not applying torque. It felt sketchy, but the disco has been chugging away happily since the HG job so it works.
I used threadlocker on the bottom set of threads on each stud. The ARP instructions don't mention it, but if I recall correctly I was following someone's advice from this forum (or another LR forum).
The instruction set is here if you want to take a gander at it.
Old Apr 6, 2018 | 09:49 AM
CollieRover's Avatar
I have to do the job outside, and using the threadlocker means you need to install the head immediately. Being alone, outside, if something goes wrong, rain, forgot something, I don't want that pressure or to reclean the holes.
What is the logic behind the bottom, not the rest?
Old Apr 6, 2018 | 10:53 AM
Saturnine's Avatar
Sounds really complicated
Old Apr 6, 2018 | 11:26 AM
To be honest, I wrote it down to use threadlocker on my cheatsheet for when I went to put them in, but for the life of me I can't find w/e forum thread I saw it in. I'd imagine you could use the ARP stuff on both sides and the nut and call it a day.
Saturnine with what I've followed you doing in your apartment's parking lot I figure this would sort of thing would be a breeze for you!
Old Apr 6, 2018 | 11:31 AM
I have to start doing a better job of bookmarking, too. There was an oil study I now cannot find! T4 it is.
Old Apr 6, 2018 | 11:32 AM
Saturnine's Avatar
I appreciate that but really I'm an idiot.
ROB99DISCOSD
Apr 4, 2018 12:38 PM
LADisco2
Oct 29, 2017 06:21 AM
lsmit605
May 11, 2011 11:50 AM
RROJ
Mar 26, 2011 02:37 PM
DickB
Jul 18, 2008 11:12 AM
