Discovery II OBD Code Help
Old Sep 26, 2017 | 07:02 AM
DFMAGuy's Avatar
5th Gear
Default Discovery II OBD Code Help
Need to tap into the knowledge base here again please as I am still on the hunt for a 03' or 04" Discovery II - Looking at one now local to me with a Service Engine Light on with an OBD reading that comes back with "P1417 secondary air system fault bank 2. P1000 (80) secondary air system fault bank 1".
What might this likely entail to resolve?
Thanks.
Old Sep 26, 2017 | 07:05 AM
LR03NJ's Avatar
Thanks.
could be the sai pump not working properly or clogged.
Old Sep 26, 2017 | 07:48 AM
number9's Avatar
P1417 Secondary Air Injection System – Low air flow Bank 2 RH (Insufficient SAI flow
during active test)
Believe P1000 is a generic code and would be n/a.
I would think since on only one side one of the small vacuum hoses for the control valves may have slipped off or is deteriorated.
mpompliano
Freelander
Jan 11, 2013 07:19 PM
ccombrink
Aug 27, 2012 04:48 AM
johnkbl
May 3, 2010 06:19 PM
alemurill
Jul 9, 2008 10:16 AM
cellman01
May 21, 2008 08:36 AM
