DIY $120 Lift
Old May 10, 2022 | 03:13 PM
  #21
andino's Avatar
They're likely rubbing on the radius arms. I had that when I was using stock wheels with 265/65/18s. You need to add spacers if that's where you're rubbing.
Old May 10, 2022 | 03:36 PM
  #22
DiscoJunction's Avatar
I'm going to hook up a gopro somewhere and do some tight turns and bumps to figure it out..
Old May 10, 2022 | 05:01 PM
  #23
whowa004's Avatar
radius arms and you will need to trim probably the bottom of both sides of the fender/wheel opening some. Turning and flexing will rub every time if things aren't clearanced..
Old May 17, 2022 | 09:41 PM
  #24
Alex_M's Avatar
Yep, I'm still running it! In fact I've had the same setup on three rigs and been very happy with all of them. Just this past weekend we had my D2 down to the Uwharrie Safari and it performed wonderfully.
Originally Posted by DiscoJunction
I was reading your post about a budget lift kit and I am curious if you kept it or if you changed it out for something else since then. Are you still running rear springs in the front? Were those stock height rear springs? Any thoughts about what you would do different? If anything. I have the Terrafirma lift springs "TF 052 PS" and "TF 052 DS" in the front. that are supposed to give me a 2-3" lift and I have 1.5" spacers in the front.. but my 285/75/16's rub like crazy... Any thoughts would be much appreciated!
jycsalas
May 22, 2020 07:59 AM
scottmb23
Apr 2, 2018 11:03 AM
Greg Vasileff
Dec 1, 2017 08:14 AM
ValveCoverGasket
Feb 13, 2012 10:05 AM
rrhyne
Jul 20, 2011 05:56 PM
