Do I Even HAVE a Cruise Control ECU?
So I am BRAND NEW to the Rover clan! Just purchased a '00 Disco SE here in Houston TX and (of course) the cruise isn't working. I have troubleshot both the actuator AND the pump- both work well. Problem is I can't FIND the cruise ECU under the dash?!? I have been thru the RAVE as well as read EVERY post regarding Rover cruise issues. I NEED my cruise! It's getting harder an harder to leave my Pathfinder in the driveway!! I used to own an import speedshop so I am fairly mechanically inclined HAHA! Seems most posts regard the D1 and not much for the D2? I'm including a shot of my underdash behind the glove- After looking at replacement pics I can't seem to find the dang box ANYWHERE?!? Any help would be awesome thanks in advance!
This might sounds like I'm being a d***, but I promise you I am not. In my experience, the cruise control on the DII sucks, mine will fluctuate about +/- 5mph, and usually takes a 3 second "hold" on the "SET/+" button in order for it to catch.
So my question is, are you SURE it's not working? You're clicking the little "/ \" looking button on the right side of the dash in, the light lights up, and then you pull the "SET/+" button back?
Thanks a TON for the clarification! I DID DL and scour the RAVE but I didn't see that pic?!? ODD! Well anyways. I have tried EVERYTHING on that dang switch (I held it from 50 down to 30!) And nothin. Everything else works GREAT! Killer vacuum and pump works fine as well! It's either steering wheel switch or that dang ECM! Ugh. Welp I got the voltages from the RAVE so I'll try an give that a shot tomorrow! I'm used to the fluctuations too- seems ANY heavy truck does it to some degree! (Unless it's just an import thing!)
Thanks again guys!
Thanks again guys!
Oh and YES I arm the cruise first - that switch is ok. I get my light on my bridge! (oddest pic EVER) I even get the click on RESUME from under the dash! It's prally the switch, but I wanna T/S the ECM first cause if IT'S bad I'm just gonna resolder the whole thing...I'm the kinda guy that fixes it ONCE for GOOD!
AuZZZie
05-21-2012 12:01 PM
Weskechi
03-29-2010 07:16 PM
Howdy all! Newbie to the scene. Actually, I don't even have one yet:) But I have a plan! A long one.
jdog35
04-19-2008 03:16 PM
