Do Magnecor 8mm Wires fit the Clips?
Old Oct 22, 2013 | 12:54 AM
Dirtnap's Avatar
Default Do Magnecor 8mm Wires fit the Clips?
Hi Guys,
Do the 8mm wires fit the stock engine mounted wire separators/clips? If not, what do you recommend to ensure they are not an issue?
Thanks
Old Oct 22, 2013 | 01:12 AM
acg's Avatar
acg
I bought a set of the Kingsborne 8mm. They will not fit the factory clips. The 7mm version should work.
Old Oct 22, 2013 | 04:48 AM
antichrist's Avatar
Kingsborne also sells clips for 8mm, and 10mm too I think, wires.
Old Oct 22, 2013 | 07:41 AM
drowssap's Avatar
they fit but are a pain, I would order the 8mm clips next time
Old Oct 22, 2013 | 08:39 AM
bosshogt's Avatar
I got mine to fit. To make pushing them in easier, add a little grease. Its a tight fit but they will go in.
Old Oct 22, 2013 | 08:41 AM
gbob's Avatar
Is this the correct product?
T25 -8mm Black Spark Plug Wire Separators- 2wires
Old Oct 22, 2013 | 08:51 AM
drowssap's Avatar
yes, I would buy a couple of 4 wire holders
Old Oct 22, 2013 | 11:14 AM
antichrist's Avatar
Originally Posted by gbob
Those should do, though I've used these: T80 Assortment of 8mm Separators 2-3-4 hole
EkaInfinitos
Jul 16, 2011 01:10 AM
Emperor_MA
Jun 26, 2011 11:28 PM
caleb
Nov 28, 2009 06:49 AM
cegibbs3
Jun 12, 2009 08:16 PM
03DiscoSE
Oct 20, 2008 08:45 AM
