Does anyone know how many hours of labor for engine replacement.
Old Dec 22, 2022 | 12:58 PM
DiscoJay99's Avatar
4wd High
Default Does anyone know how many hours of labor for engine replacement.
I’m looking to pull the engine from my discovery which has low mileage and a blown chassis, and swap into a great chassis with a blown engine im looking to purchase. I’m curious at how much labor would typically be involved so I can have an idea on price. Identical trucks, 1999 4.0 in Oxford blue. I tried to search but couldn’t find what I’m looking for.
Old Dec 22, 2022 | 01:40 PM
gecko951's Avatar
This should give you a good idea of what you're going to get into or pay someone else to get into: https://www.roverparts.com/resources...very-series-2/
Old Dec 22, 2022 | 05:03 PM
The Deputy's Avatar
Without knowing your mechanical skills...it's hard to say. Basically, you're pulling two and installing one. Me, just taking my time and everything going somewhat well...maybe a day pulling one (which is about five hours of actual work). Installing takes a bit longer and usually it's a day dropping it in and a day or less finishing it up and hearing it run.
Old Dec 22, 2022 | 07:50 PM
Extinct's Avatar
Yeah, I can get them out in about 3- 4 hrs but I have done it several times. Back in takes a bit longer, great opportunity to do all of it though, starter, CPS, coils, wires, cooling system, etc etc.
Old Dec 24, 2022 | 10:16 AM
redwhitekat's Avatar
A shop will probably charge you 12 hours easy
plus plus.
Old Dec 24, 2022 | 11:08 AM
Xanthro's Avatar
When the engine is out of the better chassis, replace the engine mounts, and transfer case mount and seals, and transmission mounts.
Also, you may want to replace all the belt pumps as well, and do everything Extinct wrote. It' MUCH easier when the engine is out.
Old Dec 24, 2022 | 01:52 PM
XRAD's Avatar
If you are doing this engine exchange yourself, better read up on how to mate the engine to transmission...VERY important alignment....
Old May 16, 2024 | 08:20 AM
rnmcguire's Avatar
I found an OEM on Ebay for about $100 brand new in the box. I'd check there first you never know you might get lucky.
landroverdude
Jan 31, 2020 04:08 PM
railroader
Feb 19, 2012 04:14 PM
zedleppelin
Apr 27, 2011 01:13 PM
miyadog1
Mar 5, 2009 11:08 PM
desmond
Defender
Jan 19, 2007 10:22 PM
