Gear locked
Old May 13, 2024 | 09:35 AM
Sean Winter's Avatar
Default Gear locked
I have a problem putting my discovery into Drive. I have to press the brake down with both feet to allow the shifter into D. Once I'm in Drive, the car functions fine. But to move the gear again, I have to use extreme effort to press the brake again. Any ideas? I'm afraid to get stuck in Drive like I did in a drive thru already. lol
Thanks
S
Old May 13, 2024 | 10:16 AM
Richard Gallant's Avatar
Sounds like the safety interlock switch is going, if you remove the bezel around the shifter you can see it and confirm it retracts. A bit of lubrication might help.
Old May 13, 2024 | 10:18 AM
mln01's Avatar
I suggest replacing the brake light switch. They're not expensive and they're not difficult to replace.
To confirm, check whether or not the brake lights illuminate when the brake pedal is pressed normally.
Old May 13, 2024 | 10:42 AM
Thanks guys. I'll check both.
Old May 13, 2024 | 08:01 PM
The brakes did not illuminate, so I’m getting a new switch. Thanks again!
S
Old May 13, 2024 | 10:14 PM
mln01's Avatar
Great. Any auto parts store should have it. No need to order it.
Old May 15, 2024 | 03:16 PM
Just wanted to leave this diagram here for others. I was able to remove the old switch, reset it, and install. Everything back to normal. I will put a new switch in for 18 bucks just bc it's cheap.
Thx
S
Old May 16, 2024 | 07:27 AM
jastutte's Avatar
Thx
S
gotta love an easy, cheap fix.
Old May 16, 2024 | 10:40 PM
Harvlr's Avatar
Good news!
Firstflight
Mar 15, 2024 09:34 AM
SheriW
May 24, 2022 07:33 PM
MysteeklRover
Apr 15, 2016 03:20 PM
Canizales
Dec 14, 2011 05:26 PM
Dino76
Aug 16, 2010 07:42 PM
