Going to pull the chopped up wiring harness today. Gotta question.
Old May 3, 2009 | 02:52 PM
tornado_735's Avatar
Default Going to pull the chopped up wiring harness today. Gotta question.
I'm going to pull that butchered up wiring harness out of the Landy today. But I was curious...do you guys know what all that harness connects to under the hood? I figure probably the injectors and the coil pack, but what else?
Not looking forward to fighting with this Intake Manifold again.
Thanks,
Aaron
Old May 3, 2009 | 04:12 PM
Well, I took a quick nap and on my way downstairs to work on the rover I realized that my tools are still in the back of the Cherokee from when I changed the Diff Fluid. The Cherokee is about 20 miles away with the GF.
Crap.
Old May 3, 2009 | 05:04 PM
discoxd's Avatar
just start at the ignition switch and throw money at the problem...
Old May 3, 2009 | 06:39 PM
Suede's Avatar
A digital camera will be your best friend in this endeavor. Take a picture each time you unplug something and mark down a notch on a piece of paper. Then again mark down a notch on a piece of paper every time you plug something in on reassembly. The pictures should help you with properly rerouting all the looms on reinstallation (did this one go up over, or below the steering column? In front of, or in back of, the dash bracket? etc). Good Luck. With a bit-o-patience, you'll conquer the beast...
theswede
Oct 29, 2015 01:05 AM
june82000
Oct 12, 2015 06:38 PM
G Reeves
Sights N Sounds
Jul 21, 2012 08:54 PM
tornado_735
Apr 27, 2009 08:25 AM
