Door “pop”
Old Feb 7, 2023 | 01:44 PM
mln01's Avatar
Originally Posted by mackendw
What is the "trick" in getting the door check strap back into position so you can put the replacement pin in? I can move it out using a pair of vice grips about 2 " but not close
enough to drop the pin in.....ideas??
I apologize for this interruption to the thread, but as a native Nebraskan, where Vise Grips were invented, I am a zealot for proper spelling of the name. Vise Grips are a well-known tool. I don't know what "vice grips" are, but the possibilities are endless ... Just havin' a little fun!
Old Feb 7, 2023 | 01:45 PM
mackendw's Avatar
they are what the vice squad use to attach to de-nut the perps ...
Old Feb 7, 2023 | 09:41 PM
Brandon318's Avatar
It's really just straight-up force that works. Bigger pliers if you have them.
Old Feb 7, 2023 | 09:47 PM
mackendw's Avatar
on the + side..it's very quiet now to open/close.
Old Feb 8, 2023 | 05:48 PM
longtallsally's Avatar
I don’t think it’s the pin. Mine came out shortly after purchase of my ‘04 and just last night I had to put the bolt back in that I put back then (I put some lock tite on the nut this time).
But my point is, ever Disco I’ve had, makes this pop. I dunno. Things still work so I don’t really care.
Old Feb 10, 2023 | 11:08 AM
mackendw's Avatar
I just replaced my pin with a new one. drove it down to match the one on the passenger side. used some anti-seize on the pin to lube it. same noise still when opening. so it has to be coming from whatever that latch with the hole in it coming from inside the door. I guess that is another weekend job...
Old Feb 13, 2023 | 11:44 AM
NVDiscovery's Avatar
I have the same noise on my driver's side doors. Lots of different lubes have made no difference.
IMO, its not the roll pin but the hole that the roll pin goes into at the body. That hole/body mount becomes elongated over time. I suppose an oversized roll pin and a resizing of the hole would remedy the situation but I haven't tried that approach. Hope that someone comes up with a good fix!
Old Feb 13, 2023 | 11:22 PM
Dervish's Avatar
My drivers door on the TD5 makes a helluva (double) pop when opening it.
The pin hole is huge. Never had a pin in it, was just nothing when I got the truck.
M6 bolt with a nylock now, but it's loose....
jimvw57
Apr 20, 2015 05:51 PM
krazzz
Feb 5, 2013 11:12 AM
RROJ
May 21, 2011 10:43 PM
bardel
Aug 2, 2010 06:39 PM
Camdisco24
Feb 23, 2008 09:43 PM
