Door handle key cyllinder
Old Aug 10, 2015 | 03:56 PM
cmmoyer's Avatar
Default Door handle key cyllinder
I usually don't use keyed entry into the truck since I have a transponder, but I went to go get a few spares made in case I ever lose it or the battery dies. So I got my spares made, and come to find out they key cylinder can't control the lock. The cylinder turns freely in the handle with no resistance. I'm guessing a the linkage between the cylinder and the lock actuator assembly has become disconnected. Anyone else ever encounter this problem? If theres a problem with the actual key cylinder and not a linkage I'm assuming I'm gonna have to replace the entire door handle assembly. Any thoughts?
Old Aug 10, 2015 | 04:41 PM
Alphamale's Avatar
Hi it may be that the lock barrel is not locating in the lock.
Old Aug 10, 2015 | 07:18 PM
abran's Avatar
Its your door lock pin, its broken.
Land Rover Front LH Driver Door Handle Pin Discovery II Aftermarket MR0010 | eBay
Old Aug 11, 2015 | 05:43 AM
drowssap's Avatar
the man is correct; door lock pin
Old Aug 11, 2015 | 07:45 AM
coors's Avatar
Let me search that for you...
https://landroverforums.com/forum/di...nt-work-74889/
Tricked306
Dec 6, 2018 11:37 AM
Awper
Jun 20, 2014 02:24 PM
ToddD
Jun 24, 2012 09:14 AM
mpmiller1980
Jul 21, 2009 06:30 PM
