door lock actuator removal issue
Old Jun 11, 2009 | 04:23 PM
muddybuddy's Avatar
Default door lock actuator removal issue
OK my rear passenger door lock actuator has given it up and I am trying to remove it on my DII 2002. Has anyone else done this removal- I have tried the RAVE manual but the procedure is for an earlier model that does not have the window slide bar blocking the way of the actuator. I have tried every way possible to slide the actuator out but cannot get it around the track. HELP.
Old Jun 11, 2009 | 10:41 PM
rrhyne's Avatar
I've done the front a couple of times, and you have to remove the window frame. No other way on those.
Old Jul 8, 2009 | 10:30 PM
skyguy's Avatar
Currently doing my Drivers door. Wow is this fun (LOL) not really, I try to add pics in new post.
Old Jul 9, 2009 | 12:12 PM
Robmcin's Avatar
Please do, I will be doing mine in the next week or two. it would be nice to see exactly what I am getting into
Old Jul 9, 2009 | 12:47 PM
AnnelieseMae's Avatar
From: Traverse City, Michigan...currently in Jerome, AZ!
My rear passenger door actuator went out too. I have not the $127 bucks or whatever it is to buy one at the moment...so I keep it locked.
But I will be doing this at some point when I get the money, after brake rotors and pads...
Old Jul 15, 2009 | 11:00 PM
skyguy's Avatar
OK I replaced the actuator door latch for the drivers door and I now have a working door lock again. I wasn't to bad, 7 screws on the door panel, 3 torx screws on latch, 2 more torx screws on window frame, and 3 bolts behind vapor barrier. The job takes about 1 1/2 to 2 hrs. The window frame has to come out the door panel has to come off, the interior cover for the mirror has to come off and the remove the latch. When you are reassembling make sure to pay attention to the cable for the mirror and window harness. The mirror wiring needs to be on the correct side of the window frame when reinserting the frame or the window will not open all the way (I did not notice that and had to disassemble the whole thing to correct that) The torx screw hole on the window frame can cause the window frame to be stuck when reinstalling carefully maneuver frame to slide in past that and test window and door lock before closing everything back up. I hope this helps
Attached Thumbnails door lock actuator removal issue-actuator-repair-002.jpg   door lock actuator removal issue-door-panel-removed.jpg   door lock actuator removal issue-window-mirror-wiring-harness.jpg   door lock actuator removal issue-door-handle-cable.jpg
kristofferzen
Sep 10, 2015 02:11 PM
NiteTrain
Oct 4, 2012 06:41 PM
