Serpentine Belt... Disco II
Old Jul 15, 2009 | 03:37 PM
SFlynn2nd's Avatar
Default Serpentine Belt... Disco II
Is this a DYI project ?
2000 LR Discovery II
Thank you !
Old Jul 15, 2009 | 03:40 PM
lipadj46's Avatar
Yes it's very easy you just need a ratchet/socket with a long extension to loosen the tensioner pulley, pull the old belt, put on the new belt, done. Make sure you get the correct belt depending if you have ACE or not.
Old Jul 15, 2009 | 03:46 PM
SFlynn2nd's Avatar
I just bought the LR forgive me .... ACE ??
Thanks for your help,
Chip
Old Jul 15, 2009 | 03:48 PM
lipadj46's Avatar
Automatic Cornering Enhancement. The ACE pump is another pump on the auxiliary belt so you would need to get the longer belt.
Old Jul 15, 2009 | 03:52 PM
SFlynn2nd's Avatar
W/O looking I assume I have this pump... I did notice the dual fluid resevoir. One being for power steering and the other for cornering or leveling ??
Chip
Old Jul 15, 2009 | 04:10 PM
lipadj46's Avatar
Sounds like it yes. It would be the pump/pulley above the power steering pump and to the right/below the AC compressor. Here is the different layout when you install it:
http://www.roversnorth.com/store/c-3...g-heating.aspx
Old Jul 15, 2009 | 04:41 PM
SFlynn2nd's Avatar
Thumbs up
Thank you VERY much !!
Chip
Old Jul 15, 2009 | 08:03 PM
How many miles on your truck, have you replaced your upper radiator hose assembly to the new system to prevent an over heat problem, are all your services done, refer to my list at the top of the Discovery section, what about your front drive shaft, has it been rebuilt yet?
Old Jul 16, 2009 | 05:38 AM
SFlynn2nd's Avatar
109K on the clock. i do not know what has been done, we just purchased it. Many new parts are evident ubder the hood however.
real_tea
Aug 21, 2015 10:14 AM
Fishman
Jan 25, 2013 02:38 PM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
