door locks
Old Jul 20, 2006 | 01:02 PM
igriego's Avatar
Default door locks
I have a 2001 DII. the problem I am having is the drivers door and passenger door
behind driver is not locking properly with the key fob. The issue is if I hit the lock
button once the passenger side doors lock. If I hit the button twice to double lock
the drivers side locks lock.. When I go to unlock the doors only the passenger side
locks unlock and the drivers side doors have to be unlocked manually from the inside.
Any help would be appreciated.
Thank You
Irwin Griego
Old Aug 7, 2006 | 01:57 AM
katbri's Avatar
Default RE: door locks
Mine are doing the same thing! They work by hand but not with the key fob.
Old Aug 7, 2006 | 12:35 PM
I would suggest you call the dealer and talk with the service manager. Their test book can set and change the locking process, I believe they can reprogram the lock system to bring all 5 doors back to their normal locking process.
Mike
Old Aug 9, 2006 | 12:12 PM
igriego's Avatar
Mike,
thanks I will give them a try.
Irwin
Lisa
Oct 17, 2005 10:00 PM
Lisa
Aug 20, 2005 11:16 AM
Lisa
Aug 8, 2005 10:31 PM
II2Go
May 30, 2005 08:31 PM
Kennydhl
Apr 18, 2005 10:54 PM
