Door Remote Trouble?
Old Jun 14, 2010 | 08:50 AM
jrover99's Avatar
Red face Door Remote Trouble?
When we bought the car it only had one key (the owner is looking for the other) the remote is broken you can visibly see this. So you have to unlock the driver door with the key which disarms the alarm, I have to open the other doors manually from the inside by pulling the door handles. How do I get a new remote and do I need to have someone (Rover) program the new remote or can I do it myself?? I tried turning the key twice and nothing but the driver's door unlocks. Any ideas on the remote please let us know.
Thanks,
Lucille
Old Jun 14, 2010 | 09:24 AM
Yes you must buy a new remote from the dealer and only they can program it for you.
If you buy one off of e-bay the dealer will not program it for you.
Your power door lock actuators are bad and thats why you need to unlock the doors by hand.
Make damn sure you lube the key hole with silicon spray before the lock mechanism breaks and you cant get into the truck at all.
Do this every 6 months as well as the latch to the cargo door, pop the Land Rover emblem off of the cargo door and spray the handle, open the door and lube the latch too.
When it gets dirty it will jamb and you wont get the door open.
Again every 6 months.
Old Jun 14, 2010 | 01:01 PM
Soccer Dad's Avatar
Default Lubing the door lock
Lucille, in Canada go to Krown Rust Control and purchase their lube: it's fantastic. You can also find the older formulation at Home Hardware but the new one can't be beat!
Seriously, even after you solve the remote problem, lube the locks.
SD
Old Jun 14, 2010 | 01:40 PM
Trying turning the key 2 times to unlock the other doors. If that works, that is the way the ECU is set up and that can be changed sometime if you do get a remote by reseting the ECU.
Old Jun 14, 2010 | 01:47 PM
jrover99's Avatar
Thanks for all the help guys I will show these posts to Jim when he gets home from work. Check out some pics I downloaded, I think a Brush Guard is in order. (lol)
jfall
May 11, 2017 11:37 PM
Matt_Attack352
Jan 13, 2014 09:55 AM
RROJ
Oct 9, 2010 07:39 AM
RROJ
Oct 8, 2010 09:56 PM
