Down pipe studs buggered - to silencer
Old Jan 27, 2017 | 11:57 PM
Luckyjayb's Avatar
If you do take it out, take off the two crossmembers and it comes out like a dream
Old Jan 28, 2017 | 03:40 AM
The Deputy's Avatar
My flange was pretty rusted out, so I went this route. Flange repair kit.
The studs on the original are press fit, and even with heat...they can be a bugger to beat out. Mainly because of the position you are in and having to hold on to the flange and beat it at the same time. Yes, it's possible to do...but a pain. I was actually able to get the three studs out of the flange over the rear axle pretty easily, but it was out in the open more.
Brian.
Old Jan 28, 2017 | 01:14 PM
Jeff Blake's Avatar
Thanks Deputy... that might be a better idea!
Old Jan 28, 2017 | 01:19 PM
Jeff Blake's Avatar
Deputy, do you have a link to the kit you bought?
And there isn't a gasket for this connection, correct?
Old Jan 28, 2017 | 03:20 PM
Luckyjayb's Avatar
Not from the y pipe to muffler. There is one where the 3 bolt flange is from the muffler to silencer
Old Jan 28, 2017 | 03:42 PM
The Deputy's Avatar
Walker Flange Repair Kit 31953: Advance Auto Parts
No gasket, but as mentioned, the rear/three hole flange has a gasket.
Brian.
Old Jan 28, 2017 | 06:54 PM
Jeff Blake's Avatar
Cool thanks.
Propane torch didn't work for me. Did a lot of drilling and dremeling and finally got them out. New bolts I picked up are a little loose in there as the old bolts had a collar around it. I don't think it'll matter. Onwards
Old Jan 29, 2017 | 03:11 PM
Jeff Blake's Avatar
Do the flanges need to sit flush with each other? No matter how much tightening I do, there's a 2-3mm gap
TRIARII
Sep 16, 2019 01:55 AM
mooni
Sep 7, 2015 02:43 AM
jimpty
Dec 4, 2011 10:06 AM
raid13
May 13, 2007 12:13 PM
Brad S1
Nov 9, 2006 04:56 AM
