Drag link removal issue
Old Jan 29, 2011 | 07:03 AM
raul507's Avatar
Default Drag link removal issue
I'm trying to remove the drag linkage to replace it and I can't get the ball joint at the end of the link to stop spinning. I can't pull it off anymore and I cant put it back on.....little perplexed. Reading the RAVE now and it just says it remove the nut and thats it.?
Old Jan 29, 2011 | 08:01 AM
Long Haul's Avatar
If you have an impact wrench is gonna be your best bet. Onece they start turning like that its a real PITA to get loosend or tightend with out an air gun. Or if your replacing it any how you can try to hit it back into place with a hammer while turning the nut.
Old Jan 29, 2011 | 09:24 AM
antichrist's Avatar
Depending on the end, place your jack under it to force it back in to the hole so you have pressure on it, or use a lever to press the end in and hold it.
Old Jan 29, 2011 | 10:50 AM
raul507's Avatar
Thanks for both of the replies. Used a jack to put pressure on it and used my neighbors compressor and impact wrench...done and dusted. Thanks guys!
Old Jan 29, 2011 | 04:14 PM
jkid's Avatar
It seems like you should be able to attach an allen wrench / hex key, (5 or 6mm - somewhere in there) into the end of the spindle to keep it from spinning. Check it out.
FINDingCLARITY
Apr 15, 2016 12:42 AM
malmberg
Aug 9, 2009 07:57 PM
bmwrovers
Jun 4, 2009 06:17 PM
Disco Alan
May 13, 2009 12:34 PM
Disco2Guy
Jul 19, 2008 02:23 AM
