Drain Plug Sealing Washer
Old Jul 10, 2007 | 09:28 PM
DiscoStu's Avatar
Default Drain Plug Sealing Washer
About to do the first oil change on the Disco. Is it necessary to replace the sealing washer with every oil change? Do you guys just pick them up in bulk?
Old Jul 11, 2007 | 08:28 AM
Default RE: Drain Plug Sealing Washer
In nerly 90,000 miles, I have only changed mine one time. When I do my 3000 mile changes, I just take the washer off and put it back on upside down and it reseals fine every time.
Since you are doing your own oil changes, I would suggest a couple of oil filters to use, the 3001 K&N or the Mobil 1 filters, the rest are real junk. Also fill the new oil filter about 2/3 full with oil before installing it.
Mike
Old Jul 11, 2007 | 08:57 AM
chakadog's Avatar
I'll have to remember that about filters... BritishAtlantic sent me a Cooper branded filter, IIRC.
Old Jul 12, 2007 | 05:33 AM
mordor110's Avatar
Disco Mike,
Do you have any experience with "Crossland" filters? I know all the farmers back in the UK used themon their Roversso I've been using them so far as I can get them from an independant Rover place local to me.
Old Jul 12, 2007 | 04:16 PM
Newfoundlandrover's Avatar
Mike,
The correct K&N oil filter for the Discovery 4.0(according to my book anyway) is the HP 2004 is it not? Or have you found another size works better?
Colorado David
Jun 15, 2021 12:31 AM
buick215
Jan 7, 2012 04:25 PM
krazzz
Jan 15, 2010 07:17 AM
hendoc3
Jul 20, 2007 03:44 PM
BMF175
Jul 24, 2006 11:43 PM
