Drain plug size
Old Oct 1, 2008 | 10:25 AM
theworks001's Avatar
Default Drain plug size
Does any body know the size of the drain plug for the tranny and Differentials.
thanks
Old Oct 1, 2008 | 10:31 AM
Default RE: Drain plug size
You mean what size wrench?
The diffs take a 1/2" rachet. Just stick the square end of the rachet into the hole and away you go. You will need a short extenstion, but that is what you use.
As far as the drain plug on the trans oil pan, dont know. I just kept switching sockets until I found the one that fit.
Old Oct 1, 2008 | 10:36 AM
Landzu's Avatar
Just drained my trany today its a 17mm.
Old Oct 1, 2008 | 10:12 PM
tacomatech's Avatar
8mm hex drive for the fill plug, 5mm hex drive for the drain plug on the tranny. 1/2" ratchet for the t-case fill and drain plugs as well as for the differential drain plugs. The differential fill plugs are a 21mm head and are plastic so be very careful not to over-torque them, as they will snap easily. I am assuming the vehicle in question is a Disco II.
Cliff
Jul 29, 2013 11:01 AM
Rover_Hokie
Jan 15, 2013 01:10 AM
dansgt
Oct 9, 2012 09:04 PM
s10lowrider1994
Feb 25, 2012 07:01 PM
Lchop1.8T
Sep 19, 2011 03:00 PM
