draining a radiator?
Old Oct 12, 2008 | 02:24 PM
pilsner's Avatar
Default draining a radiator?
ok what is the quickest way to drain my disco II's radiator i didnt see a spitcock under the radiator. am i missing something obvoius here?
pilsner
ft lewis WA
2000 disco II w/135k
Old Oct 12, 2008 | 02:35 PM
Default RE: draining a radiator?
Remove the lower radiator hose from the radiator. It will be empty in about 2 mins.
Doing it that way will remove about 98% of the coolant.
A petcock would be nice.
Old Oct 12, 2008 | 03:41 PM
NiteTrain's Avatar
no petcock on a DII? well I guess finding out now saved me some time for searching for it.
Old Oct 12, 2008 | 06:00 PM
It is very supprising, there isint one on a DI either. If there is I sure cannot find it.
Old Oct 12, 2008 | 07:38 PM
starcraft's Avatar
Hey spike you said that removing the lower hose will get rid of 98% of the coolant. Is that 98% of the coolant in the radiator or 98% of the coolant in the entire truck. I am asking because I want to do a full coolant changeon my truck. Sorry to butt in on someone elses post.
Old Oct 12, 2008 | 07:50 PM
That is 98% of what is nin the entire truck. To get it all out once drained replace the lower hose, fill with water, turn the heater on and idle for 10 mins, drain and then fill with the new coolant.
It will drain better if you also unhook the top radiator hose from the truck first.
So remove the upper hose, then the lower one.
Drain.
Replace hoses.
Refill with water idle with heater on for 10 min.
Remove top hose then lower hose. It is best to let it cool for 10 min before you do that so you dont get burned.
richief556
Jul 23, 2009 08:29 AM
lipadj46
Jul 11, 2009 08:59 AM
llPANCHOll
Jan 3, 2009 03:47 PM
94LWBrangie
Sep 27, 2008 11:23 AM
barcroft
Sep 27, 2008 09:44 AM
