Dreaded 2003 DII with Misfire, Low Compression, Ticking,
Old Mar 22, 2019 | 01:58 PM
neuropathy's Avatar
Default Dreaded 2003 DII with Misfire, Low Compression, Ticking,
I have the dreaded 2003 Discovery II and it’s giving misfire codes in cylinder number 5, as well as showing low compression (75psi). It also ticks... I live in California in a county where I can’t smog the vehicle for registration completion without getting rid of any engine codes. With low compression, I can’t do that... At least not any way I know of. Anyone have any ideas? Is this engine done for?
The vehicle still drives pretty well, a bit stumbly sometimes, but it makes it up 3000’ of mountain and down regularly.
What’s next? Any advice? Sell it as is / if DMV allows that? There are six counties in CA that don’t require smog certification (including Riverside, San Diego and I believe San Bernardino) - maybe I can sell it there without as much hassle? I was hoping to smog it there, but I‘d expect the DMV would shoot that idea down since I don’t have an address there or anything... Sad times. I like this one a lot. It’s black/black with bad clearcoat failure on the hood and roof, but I’ve fixed a lot of its issues. I also have another Range Rover Classic I need to work on (ABS, or some serious braking issue). Please advise!
Does anyone think it’s worthehile swapping motors? I’d rather not, of course - This vehicle is a daily driver and I’m in need of another vehicle - maybe a 2010-2012 RR HSE or Sport - any words about that? Hope everyone has a better weekend than me! Cheers
Old Mar 23, 2019 | 09:43 AM
No Doubt's Avatar
Pull your #5 spark plug and do the $12 vapor test. You are expecting to find a blown head gasket which is easy enough to replace.
Test first, then wrench.
Dont fear this job. Motor stays in.
Old Mar 23, 2019 | 11:20 AM
Saturnine's Avatar
Yeah, HG isn’t all that bad. Just takes time and determination
Old Mar 23, 2019 | 04:25 PM
Extinct's Avatar
As long as the engine is not making any bad noises low compression is probably not a big deal. #5 has no water passages though, so if it was blown I would expect an adjacent cylinder to be low compression also unless it blew to the intake valley, which I have never seen. Could be blown to the outside, but that sounds like a giant exhaust leak. Could be a broken rocker, that would drop compression. You could take the upper intake and valve cover off to look at the rockers. You could get a leak down tester and see where the pressure is escaping, that would give you an idea of what you are in for. Either way I would keep it and wrench on it, nice looking truck.
tashrocca
Aug 26, 2019 04:30 PM
jkid
Jun 8, 2019 02:28 PM
LandBeard
Nov 22, 2017 06:38 PM
mtrdrms
Feb 11, 2013 03:39 PM
Erik
Jun 17, 2007 11:59 AM
