Drip Rails Replacement
I just did most of mine. You don't even need any hand tools.
I have the driver side A-pillar finisher for sale if you want one. It's not hard to break those when installing, especially a used piece as the plastic mounting tabs are compromised and faulty from age and UV damage. So I bought a genuine model but before it arrived by mail I had already made a recycled piece work well enough that I didn't want to risk damaging anything while doing it over again.
Same thing with the drip rails. I pulled some from wreckers, bought some new. Started off using the 2nd-hand pieces and finally used the new parts where the used ones even cracked trying to get them on. That plastic stuff is really fragile with age so you can do like I did or buy all new ones and take your time hooking them in place. The corner pieces on the back door are the easiest to break and the long 1 going down the side is the easiest to get into place.
slanginsanjuan (03-26-2020)
dr. mordo
01-28-2020 03:05 PM
slanginsanjuan
02-16-2017 08:59 AM
