Driver side catalytic converter was empty!
Old Oct 23, 2013 | 09:14 PM
lmcgrew79's Avatar
There are no codes left. Ive only owned this vehicle about 2 months. The last of the codes i was getting was P0171 and P0174. I drove the vehicle around today and got nothing. Its seems to be running smoother and better. The engine was replaced by land rover early in its life according to the last owner as im the 3rd. So its hard to tell what those cats have been thru. Im at 135000 miles, and have fixed quite a few things on it. MAF was unplugged, it was also only firing on 7 cylinders as one of the plug wires was bad. Passenger side O2 sensor was bad. Im getting it worked out a few things at a time.
Spark Plugs 09/03/13
Transmission Fluid 09/05/13
Power Steering Fluid 09/05/13
Brake Fluid 09/05/13
Oil & Filter 09/05/13
Air Filter 09/05/13
Transfer Case Oil 09/05/13
Tires 09/03/13
Waterpump & Bolt Kit 09/03/13
Power Steering Rebuild 09/03/13
Belt 09/03/13
Hose Stat to Waterpump 09/03/13
Power Steering Pump Gasket 09/10/13
Drag Link, Rear Link & Damper 09/10/13
Washer Sprayers Hood 09/19/13
Arm Rest Driverside 09/19/13
Cup Holder Rear 09/21/13
Exhaust Gaskets & Bolts 09/24/13
2000 Locking Diff 10/01/13
Crank Position Sensor 10/10/13
Rear Door Subs 10/20/13
Magnaflow Cats 10/21/13
Old Oct 23, 2013 | 09:20 PM
lmcgrew79's Avatar
Head gasket is ok for now anyways, seems to be leaking some oil in the rear from somewhere im assuming, the valve or valley gaskets, those will be next.
Old Oct 24, 2013 | 08:06 AM
Paul Grant's Avatar
So what did you do with the one good cat?
Old Oct 24, 2013 | 08:19 AM
jfall's Avatar
Had to replace the cats on the old D1 as they had become ineffective.
One did rattle a bit.
1997 Land Rover replace catalytic converter and head gaskets
Old Oct 24, 2013 | 07:16 PM
lmcgrew79's Avatar
Still in my garage
Old Oct 24, 2013 | 07:30 PM
ZGPhoto's Avatar
Originally Posted by lmcgrew79
Still in my garage
Bring it to a metal scrap yard, probably at least $100 worth.
Old Oct 25, 2013 | 12:49 PM
nychaze's Avatar
Off topic....
what is your garage floor coated with (brand) and does it hold up well?
Old Oct 25, 2013 | 03:36 PM
lmcgrew79's Avatar
Its sherwin williams armourseal 1000 epoxy topped off with rexthane ailphatic urethane.
lyleorszulak807
Jan 6, 2011 07:14 AM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
