Driver side O2 sensor access
Old Jun 18, 2018 | 07:07 PM
mx468's Avatar
Default Driver side O2 sensor access
Just wondering if I can access the driver side o2 sensor from the top through engine bay. I can't remember how I changed my first Disco 2's sensors, its been a while. I tried getting it from the bottom this time around with a offset wrench but I can't seem to get enough leverage on it. Also the thing won't budge. I already pb blasted it. Any suggestions would be much appreciated.
Old Jun 18, 2018 | 10:42 PM
User's Avatar
There was one time I used I think a crows foot wrench to break it.. wasn't on a Disco but may be worth a try
Old Jun 19, 2018 | 07:10 AM
Alex_M's Avatar
Pb blaster has been confirmed to not actually do jack. Try aix of ATF/Seafoam 50/50.
I always got at mine from underneath with a 12" box wrench. If that's still not enough you might have to get some extentions and some wobble joints to reach from up top with a breaker bar or torque wrench.
Old Jun 19, 2018 | 11:03 AM
mollusc's Avatar
I did both my upstreams just a couple of weeks ago. It was tight getting to them, but not horribly so (the downstreams are worse). I can't imagine trying to get to either of them from above.
Spend the couple of dollars to get an offset O2 socket. It will make things much, much easier.
Old Jun 19, 2018 | 11:54 AM
stxscott's Avatar
I went from underneath and used the offset tool from an O2 sensor tool kit. Easy.
Old Jun 19, 2018 | 12:25 PM
Best4x4's Avatar
Open end wrench has always got em off for me from underneath. I do spray em & let em soak for a bit first or crank it for a minute to warm up the pipes.
Old Jun 19, 2018 | 05:50 PM
Fallstaff's Avatar
Pretty sure that was the one I did from the top.
They're all super awkward to get at. I found what works best is to get a well trained but extremely strong spider monkey with small hands to get them in and out.
kip lightning
Jun 8, 2015 03:47 PM
cornbreadj
Feb 27, 2014 11:01 AM
bcolins
Oct 3, 2013 07:15 AM
pinkytoe69
Aug 16, 2012 03:47 PM
DiscoRover007
Jun 28, 2011 06:26 PM
