O2 Sensor stuck
Old Jun 22, 2011 | 04:49 AM
DiscoRover007's Avatar
Default O2 Sensor stuck
So I need to replace my passenger rear O2 sensor as I am running codes. It's like the damn thing is welded on there. I had the right size wrench on it and everything and when I thought I had it turning, all I had accomplished was that I was beginning to strip the damn thing. Any suggestions?
Old Jun 22, 2011 | 05:40 AM
drowssap's Avatar
you can try soaking it with some Pb Blaster, but you have to remember that has been in your exhaust pipe superheated and cooled countless times over the last 8-years. It is not going to want to come out; its pratically brazed in there at this point. Try a GOOD 02 socket and a breaker bar.
Old Jun 22, 2011 | 07:23 AM
lordmorpheus's Avatar
Spray it heavilywith PB Blaster, let it soak for several minutes, and try a pipe wrench if it's stripped too bad to get a normal wrench on.
Old Jun 22, 2011 | 07:46 AM
DarylJ's Avatar
What did you strip? The wrench flats on the sensor or are you spinning the sensor and its going nowhere?
If you are stripping the wrench flats, stop and try penetrating oil as already recommended. Although I never bother with that with O2 sensors.....I go right to heat. That's what typically gets them out. MAPP gas might work, oxycetalyne almost always does the trick.
Old Jun 22, 2011 | 08:36 AM
DiscoIIBrandon's Avatar
One of mine was a real pain too...I soaked them all in PB Blaster several times, but for that last one I took the car on a short drive to heat it up and then broke it loose.
Old Jun 28, 2011 | 06:26 PM
Just wanted to say thanks. PB blaster did the trick. I forgot how much a pain in the *** these sensors can be lol.
KlamathMatt
Apr 17, 2020 05:27 AM
HawesEA2
Dec 17, 2016 09:47 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
smyevich
Aug 31, 2006 01:31 PM
