Drivers Door won't unlock with fob
Old Apr 1, 2018 | 10:29 PM
xargon15's Avatar
Default Drivers Door won't unlock with fob
I have a weird issue with my 2003 D2. My fob works fine, unlocks all the doors, including the rear. The problem I have is that it won't unlock the driver's door. So no matter what I'm stuck using my key in the door to open all the doors. Any suggestions on where to start with this?
Old Apr 1, 2018 | 10:34 PM
DKPhoto's Avatar
When you use the fob does the driver side door lock **** pop up like the rest?
Old Apr 1, 2018 | 11:09 PM
LR03NJ's Avatar
Just make sure this green plastic moves back and forth when you lock and unlock. If not, it has to be replaced
Old Apr 2, 2018 | 11:07 AM
DKPhoto's Avatar
Exactly like LR03NJ said above, just had the same problem and I replaced the door lock actuator with a new one and it works like new.
dan_t
Jun 26, 2022 08:11 PM
Drubie22
Sep 24, 2014 09:29 PM
kpl1228
Aug 19, 2012 05:33 PM
Paul_VR6
Nov 16, 2010 09:29 PM
CL_Reatta
Jul 3, 2007 12:00 AM
