Drivers Side Draft
Old 02-17-2018 | 03:11 AM
robert.juric's Avatar
Default Drivers Side Draft
Does anyone else experience a draft inside the vehicle while driving? On my D2 its right about head/neck height and quite frustrating. On some of the colder mornings I've had to wrap a scarf around me or assume a center driving position.
It's not the windows and I have no water leaks. It feels like its something around the A or B pillar higher up.
This may seem like a simple question, but I painted my headliner last year and had to remove trim and pillars to get to it. It's very possible I missed something on re-install.
Old 02-17-2018 | 04:07 AM
The Deputy's Avatar
Check to see if the vertical guides (that the door glass ride inside, while moving up and down) has dropped down. When the felt guides slid down, this creates an opening between the glass and track/channel.
Brian.
Old 02-17-2018 | 12:09 PM
LR03NJ's Avatar
Last time I saw in here someone missing the rectangular plastic part below in the picture 1. Otherwise the rubber door seals are gapping. Add a foam seal round. Image 2
Old 02-17-2018 | 12:11 PM
LR03NJ's Avatar
dont know why cant upload images
Old 02-17-2018 | 12:35 PM
Alex_M's Avatar
try uploading to imgur.com and then copy the link. you don't need an account
LR03NJ (02-17-2018)
Old 02-17-2018 | 04:58 PM
OffroadFrance's Avatar
Ironically I've experienced a similar thing in the D2, I reckon it's often when just starting and the blower pushes warm are around and the cold air drops down at the front as it entrains by the warm air into the cabin. It only happens until the heater warms up but you'll still notice that there is plenty of cold air around the drivers door area.
Old 02-17-2018 | 07:46 PM
shady milkman's Avatar
I feel it coming in from my door handle, weirdest thing
Old 02-18-2018 | 06:43 PM
longtallsally's Avatar
Plastic moisture barrier may be missing.
Old 02-18-2018 | 08:19 PM
KernowDiscovery's Avatar
I have the same issue with my DII. It started this year after I had the headliner reupholstered. I'm hazarding a guess it's the seal on my back passenger window as it sounds a bit windy back there and the draft wafts up into the driver's seat and wraps its way around my head and neck. I've poked around a bit but haven't pinpointed the culprit yet. Coincidental that it started when the headliner was removed and recovered? Probably not.
Old 02-18-2018 | 09:43 PM
DiscoCam's Avatar
Sometimes, the door frame bolt on the front of the door will get loose. This allows the frame to wobble at speed and let in air. Sounds bizarre but it's happened to me on both of the D2s I've owned. So I would just go and check it, it's a torx T40 I think.
Quick Reply: Drivers Side Draft
