drivers side window problem
Old Apr 13, 2009 | 02:44 PM
alphawolfman's Avatar
Default drivers side window problem
Was trying to remember the trick with a block of wood to keep the window from going all the way down and coming off the track. I believe some regulator wheel on the motor assy is broken. Anyone remember the details of the wood block trick? Until I can find the replacement part.
Old Apr 13, 2009 | 03:02 PM
I would guess that the trick would be to remove the door panel and stick in a block of wood.
www.roverlandparts.com
You can also replace the broken roller.
Old Apr 13, 2009 | 03:23 PM
Better yet repair or replace the window regulator, it is not that big a deal.
Old Apr 13, 2009 | 09:09 PM
jkid's Avatar
That big regulator gear that the motor turns has some pretty weak welds on it. If one weld breaks it allows the regulator to loosen and run off of the motor's gear when it gets to the bottom. If that is it, just weld it back on, or maybe drill it and bolt it (I welded mine, bolts might not fit). If you don't fix it, the rest of the welds will be breaking soon and you'll be stuck.
twoxred
Oct 4, 2021 07:07 AM
scwkof
Jan 16, 2010 10:28 PM
alphawolfman
Nov 17, 2008 06:34 AM
lionel
Oct 15, 2007 10:53 AM
bruxros
Aug 5, 2005 01:54 PM
