Driveshaft - 03 Discovery II
Old 07-20-2017, 06:05 PM
lively's Avatar
Default Driveshaft - 03 Discovery II
My drive shaft in my 03 Discovery needs replacing. Is there a shop in Atlanta that would have one in inventory, if not, any good options for finding one on line?
Old 07-20-2017, 06:57 PM
LR03NJ's Avatar
Check lucky8. If not just google it.
Old 07-20-2017, 07:30 PM
wynhd's Avatar
X2 on Lucky8, Eric or Justin will get you taken care of quickly and without breaking the bank.
Old 07-21-2017, 05:40 AM
lively's Avatar
Thank you. The dealer quote is 1,412.
Old 07-21-2017, 06:11 AM
Rdr8887's Avatar
I'm under the impression that a driveshaft should be around $400 or $500. Also check salvage yards. A driveshaft can handle a whole lot of miles.
What is wrong with yours?
Old 07-21-2017, 06:38 AM
Wow. You can do this yourself. That is about $1000 too much.
Old 07-21-2017, 08:04 AM
X1 ........... easy-peasy to fit yourself, 1-1.5 hours work.
Old 07-21-2017, 04:22 PM
lively's Avatar
The dealer said my U-joints are failing which based upon what I have read is a common theme.
Old 07-21-2017, 04:24 PM
lively's Avatar
Agreed. Never done it but at that price I sure can learn how too.
Alex_M's Avatar
This isn't true for a D2 because of the proximity to the catalytic converters which give off a ton of heat. I would never use a junk yard unit except in a pinch.
D2 shafts have to be retrofitted with greasable u-joints (aftermarket already have them) and they have to be regreased at every oil change.
Quick Reply: Driveshaft - 03 Discovery II
