Driveshaft
Old Apr 11, 2021 | 04:19 PM
Triddell62's Avatar
Default Driveshaft
I'm trying to take off my front drive shaft to check a noise, Idk if it's just rust or I'm missing something but the rear end of it won't come off.. I took off the 4 bolts and nuts from the front end, the back of it I took the nuts off but can't get the bolts out (not enough room) am I missing something?
Old Apr 11, 2021 | 04:26 PM
zski128's Avatar
Bolts are captive and do not come out unless you remove the flange.
Old Apr 11, 2021 | 04:28 PM
mollusc's Avatar
You don't need to take the bolts all the way out. The driveshaft should pull off of them. Perhaps knock it with a wooden or rubber hammer (being careful not to be under it when you do so).
Old Apr 11, 2021 | 06:59 PM
Triddell62's Avatar
Been trying for hours to get it off, don't know what to do now. I sprayed penetrating oil around it so hopefully that frees it
Old Apr 11, 2021 | 07:16 PM
ahab's Avatar
You need to strike it with a mallet. It will come off. there's nothing else holding it on other than corrosion. As mollusc points out, once free gravity may bring it crashing down more quickly than you're prepared for so be mindful of that. Ideally put a block of wood against the first yoke and strike the wood with a mallet.
Old Apr 11, 2021 | 09:11 PM
Best4x4's Avatar
Put 1 or 2 nuts just barely threaded back on, then wack it with a mallet. That way it will break free and not come crashing down
Old Apr 11, 2021 | 09:13 PM
ahab's Avatar
Hahaha. Duh...
jimvw57
Mar 21, 2021 10:11 AM
KansasTrails
Oct 12, 2016 09:50 PM
me6067
Jul 22, 2014 11:39 AM
Jerry B
May 7, 2013 04:10 PM
Mountain Goat
Dec 3, 2010 10:26 AM
