Driveshaft disaster averted
Old Dec 6, 2015 | 08:48 PM
DoubleK's Avatar
Default Driveshaft disaster averted
Got Lucky! From following this community since day one of D2 ownership, I've no doubtedly saved my self from several misfortunes. But, if you've ever worked on household electrical, you sort of start to get cocky after awhile until you get shocked (again). So, I knew the driveshaft was a ticking time bomb as no sign of ever being updated and 187k on the clock. I figured I would know when it started to drive weird and I'm the only driver (for reasons documented on this site), so I rolled the dice. Today, while doing a little Sunday pavement driving with the kids I started noticing the engine feeling like it was stumbling with a wobble reverberating through the vehicle. It certainly wasn't enough to normally think driveshaft, but it was the first thing across my mind due to this forum.
I had to really look close to see the brewing problem and I even had to do some prying with a screw driver to confirm for certain. Basically, the back of one of the u-joint caps had what appeared to be a dust cover just slightly bent, but as soon as I pried on it, little pieces of broken needle bearings popped out with lots of metal dust. Cheers to everyone who takes the time to write on this forum!
If I can figure out a way to post pictures I will.
Old Dec 6, 2015 | 10:59 PM
dr. mordo's Avatar
Yep, you dodged a bullet. Hope you played the lottery today.
Congrats!
Old Dec 7, 2015 | 05:46 AM
drowssap's Avatar
your lucky day
robert.juric
Nov 3, 2022 06:08 PM
cmb6s
Feb 17, 2015 08:30 PM
thorgal
Dec 8, 2014 09:02 AM
llPANCHOll
Feb 7, 2009 09:51 PM
jusspasd
Oct 2, 2006 01:15 PM
