Driveshaft Question
Driveshaft Question
I am replacing my driveshaft as part of the checklist of items to address according to the sticky thread. I bought my truck used and it now has 83,000 miles on it (I assume that the shaft on the truck now is the original). Everything seems to be working ok with it but I was just curious as to what might be some symptoms of a worn shaft or one that might be failing. I have a few quirky things going on that could be shaft related but I am not sure if it is a driveshaft issue or not.
Any comments welcome.
Thanks
Thanks
on
Do not wait for a sympton, which would be a failure possibly taking out the tranny. Go inspect the 3 u-joints on the front shaft, they must all have a grease fitting, if only one does you are driving a truck that can fail at any time. By the way, how often do you grease your drive shafts?
robert.juric
11-03-2022 06:08 PM
