driveshaft rebuild question
Old May 21, 2010 | 02:12 PM
vandev's Avatar
Default driveshaft rebuild question
Hey, i had a noise comming from the front driveshaft area i could hear from the cabin. It sounds like a squeeky mouse. The shaft has no rust and looks almost new as the bolts and nuts that attach it to diff and transfer case. i put up on jack stands as i could only hear when in gear. I let it run on jackstands but could not hear it. I put in neutral and started to turn front wheel back and forth a bit to get front shaft moving and can hear the squeek. very faint squeek. It is comming from the back double cardian maybe the centering ball... I am going to pull today and rebuild. i am really debating not going serviceable as it another item to forget to grease and go bad. I was considering wraping the cat and making a heat sheild. I ran truck for 20 minutes and the cat did not make the shaft that hot as i could put my hand on it and hold it. I live in florida so it's always 100 degrees on the truck.... Anyone want to chime in?
thanks Chris
Old May 21, 2010 | 04:01 PM
mwindth's Avatar
thanks Chris
Hey Chris...I just want to eliminate the obvious, but you did replace the front u-joints with greaseable ones already, correct?
Old May 21, 2010 | 04:12 PM
vandev's Avatar
Default no
no, i just got the truck and has been sitting in my driveway so i can fix the pile...
The noise is comming from the double not the front one next to the cat. I have read where you can just replace the double and check the centering ball if it needs replacing. It's weird ..well like all the kookie stuff on this truck as i went outside about a hour later and could not duplicate the sound turning the shaft...
Old May 21, 2010 | 04:37 PM
mwindth's Avatar
Replace all three u-joints and the centering ball kit as soon as possible. If you think it is a chore to grease every 5K miles, it really is not. It is a very simple 10-15 minute job. And not to mention, much easier (and of course cheaper) to replace than a transmission. Though I do recommend letting a driveline shop do the rebuild, unless you have lots of patience, beer and a blow torch to get the centering ball out.
I used these parts, ordered from here:http://www.rockauto.com/
1 quantity "center ball kit" Precision part #617
3 quantity "u-joints" Precision part #344
Old May 21, 2010 | 05:09 PM
vandev's Avatar
Default thanks
I have no problem doing it myself. Have the tools, slide hammer ujoint puller and a ton of beer.. well and tequilla for thoes special moments..
I am becoming quiet effecient at rebuilding other peoples crap on these piles.. i may move up to jagermeister..
Old May 21, 2010 | 05:14 PM
mwindth's Avatar
LOL...tools, check...alcohol, check...git 'er done.
Old May 22, 2010 | 07:34 PM
antichrist's Avatar
Read this thread (including the links): https://landroverforums.com/forum/sh...ad.php?t=29302
Lube it every time you change the oil and you won't forget, unless of course you forget to change your oil.
If you use sealed u-joints you should plan on rebuilding your propshaft every 40k miles.
Old May 25, 2010 | 05:21 PM
vandev's Avatar
Thumbs up thanks
Thanks Tom...
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
jck09
Mar 8, 2010 09:47 PM
