Driveshaft safety loop
Old Mar 27, 2018 | 07:25 AM
ZGPhoto's Avatar
I had considered this at one point for a short moment, and then realized it just made sense to not be cheap and spend money on a driveshaft.
Old Mar 27, 2018 | 08:05 AM
LR03NJ's Avatar
Exactly! I dont think there is enough bracket or catch that will stop the torque and weight of the shaft when it breaks.
Old Mar 27, 2018 | 09:44 AM
mln01's Avatar
Do we know of any instances of a properly built, well maintained driveshaft going rogue? All the instances I recall were with non-greasable, original equipment shafts.
I understand the appeal of the safety loop idea, but in this case I think a belt may be enough, no suspenders needed.
Seems to me that if anyone here is aware enough of the problem to understand why a safety loop could be useful they're more than likely also aware of what type of driveshaft to have installed and how to maintain it.
Old Mar 27, 2018 | 10:02 AM
Saturnine's Avatar
Yeah i guess i was thinking of a belt dealio initially and not a hoop made out of metal as well.
Old Mar 27, 2018 | 11:48 AM
LR03NJ's Avatar
I think the best way like mentioned is inspection and maintenance. Even the best industrial belt or thickest conveyor belting is a long shot. Mainly because the shaft breaks in different places. Front joint, spine and the rear joint. If only one part has a support, once it breaks it will swing the other way and damage other parts. But securing all points will be difficult to mount it securely since space and location is difficult.
Old Mar 28, 2018 | 07:02 PM
abran's Avatar
You mean like this?:
Old Mar 28, 2018 | 09:43 PM
Saturnine's Avatar
That is going to do nothing if the joint breaks at the rear axle
Old Mar 28, 2018 | 10:13 PM
abran's Avatar
That is a stock item on a P38 Range Rover in its natural location at the forward section of the rear driveshaft.
But, could be mounted at the rear section of the front driveshaft on a D2.
Old Mar 29, 2018 | 08:09 AM
Alex_M's Avatar
That's exactly what I'm talking about. Slightly different design than the universal one, but same idea.
As requested by France, here are the pictures. First is the bone stock truck, second is mine. I think I'd place the loop approx where the balancing weight is on the stock truck. There appears to be plenty of room, but the floor pan isn't flat there; it beds up into the transmission tunnell. I'd have to figure something out for that.
primussucks
Oct 9, 2013 09:00 PM
jaydog101
Nov 28, 2011 05:35 PM
MarkKV
Aug 4, 2010 09:03 PM
rvrchk320
Dec 4, 2007 10:14 AM
yoeman
Jan 28, 2006 09:04 PM
