Drivetrain Slap
Old Jul 4, 2009 | 10:31 PM
JBEGIN's Avatar
Originally Posted by Urban Panzer
I would just like to point out that drive train "slap" is NOT normal at all!!!! especially at the speeds your talking about.......My car has now done 92,000 miles, has been used offroad and there is NO slap at all........
it means something is worn out "badly". If its a series 1, then its "usually the "A" frame bush, if its a series 2, could be a number of things INCLUDING the front drive shaft.
Besides front driveshaft, what else could it be under there that causes drivetrain "slap"
Im curious to know as mine does this every so often, it helps to have ujoints greased well...
Old Jul 5, 2009 | 09:50 AM
DarylJ's Avatar
Not LR specific at all, but after you've checked your shafts, there is always ring and pinion lash. Let your rears and/or transfer case be abused badly enough (from poor maintenance intervals or incorrect fluids) and you'll start wearing away the faces of the gears. You'll feel that in the drive train as lash.
Depending on where it is, it's possible to shim some without replacing gears. In other places and if it's far enough gone, it's just not practical.
If you get down to that, I'm sure there are plenty of people here that can give you an idea of how far your rear yolks should turn freely with the shafts disconnected as well as for the transfer case. That's usually the quickest way to get an idea.
Old Jul 5, 2009 | 11:06 AM
Chazz1918's Avatar
4th Gear
Default Oy
OK, now I don't feel so complacent. It's a Series II but I haven't crawled under there either. I will have to bring this up with my mechanic. So much for ignorant bliss. Thanks gain it's better to be aware. But I don't think I would invest 5K in a preventive fix, probably wouldn't spend it in a repair either. Don't really know. I'll post the results of my further investigation.
Chazz
Old Jul 5, 2009 | 12:36 PM
The preventative measure only costs a couple of hundred dollars, the repair costs close to $5k.
Old Jul 5, 2009 | 07:52 PM
lrlover's Avatar
4wd High
I know im alittle late but i found out the hard way and yes it is most likely the front drive shaft as i have replaced 2 on my 2002 disco II. listen to disco mike he knows what hes talking about.
Old Jul 10, 2009 | 08:30 PM
Chazz1918's Avatar
4th Gear
Default Time to eyeball it
OK, found a new mechanic who looks pretty good. Pretty much lost faith in the dealer. Bringing it in Thursday for a complete inspection by both of us. Showed him the Thread here. I'll let you all know what I see when we put it up on the lift.
Chazz
Old Jul 10, 2009 | 10:17 PM
LuvToDisco's Avatar
Completely normal from my experience. My Disco has been known to "slap" since new. Go down the highway at speed, let off the gas and then get back on it and you will feel and sometimes hear the slap, whcih is more like a "thunk". New drive shaft did nothing to change that. You learn to let off and get back on the gas gently.
AllRover
Jun 12, 2007 04:21 PM
Doak
Oct 11, 2006 11:39 AM
bmartin2
Feb 18, 2006 02:49 AM
Pilk
Mar 22, 2005 12:28 AM
