Disco problem:Can't remove key
Old Jul 7, 2009 | 07:16 PM
vpad's Avatar
Default Disco problem:Can't remove key
Just purchased a 98 Disco from an auction. It starts and drives nice, but I can't remove the key from the starter switch unless I disconnect the battery???
A mechanic ran a scanner and the only code that came up was P1193.
Has anyone else had this issue or have suggestions?
Thanks in advance.
Old Jul 7, 2009 | 07:21 PM
Pop the trim piece off of the gear shift ****, tighten the nut until the key come out.
Should only take a couple of turns on the nut.
And since you just bought the truck here is some light reading for you.
https://landroverforums.com/forum/sh...ad.php?t=21328
Old Jul 7, 2009 | 07:44 PM
jmt's Avatar
jmt
What are the heat riser pipes on my 4.6L? They're all running off exhaust, to a pump and diaphragm. The diaphragm's are controlled by vacuum.
The entire system has been a source of problems since I bought the truck. A trusted mechanic told me it was an EGR system.
Old Jul 7, 2009 | 07:46 PM
If you start a new thread we can better help you.
Old Jul 10, 2009 | 10:35 PM
vpad's Avatar
Thanks Spike! Tried it and it worked.
What do you know about running board, license, and fog lights. Neither of them work. Already checked fuses and replaced bulbs. Do I have to buy an entire unit for the front fog lights or can I replace bulbs only? All other lights work.
98 Disco
Thanks in advance.
wheelgarage
Oct 1, 2011 03:12 PM
caleb
Jan 6, 2010 11:26 AM
hwild77
Dec 17, 2008 02:32 AM
cryptic
Dec 6, 2007 02:32 PM
Frazierr
Feb 5, 2007 06:39 PM
