dropped valve cover bolt into engine!!!!
Old Feb 19, 2010 | 09:01 AM
CandiMan's Avatar
Originally Posted by 03discoman
i wonder if i carefully remove the oil pan gasket, could i reuse it after its cleaned up and sealed either side with RTV?
It all depends on how the gasket comes off. Generally speaking, if the engine hasn't been through several started or gone through several heat/cold cycles, more than likely you can reuse the gasket with some care.
FYI, the next time a bolt drops to the oil pan, you can leave it. Once in the oil pan it poses no further danger. It can not be sucked up into the oil pick-up tube.
A little too late since you already removed the intake manifold for nothing.
Old Feb 19, 2010 | 02:37 PM
03discoman's Avatar
i pulled the pan today and there it was, i clean the pan up and resealed using the gasket and a shet load of rtv, i also did the valve covers and valley pan today.
hope that doesnt happen again.
Old Feb 19, 2010 | 03:05 PM
lipadj46's Avatar
Stuff towels in the open engine holes to prevent this.
focusontheworld
Oct 21, 2012 01:00 AM
Discolife
Nov 29, 2011 02:08 PM
Bryan H
Jul 2, 2010 12:57 PM
GJgo
Jun 26, 2009 08:54 PM
rlgMcoupe
Mar 18, 2009 12:19 PM
