Dual-Camera Dash Cam
Why I had my headliner out to fix the sunroof leaks, I ran the wires for a dual-camera dash cam,
The rear camera was tough. I had to run the wire threw the rubber harness hose in the hinge area, and up through the 3rd brake light wire hole. It was worth it to get a clean installation. I like the picture-in-picture on the monitor, and that I can connect my phone to it via wifi and download clips. That thing above by rear view mirror is a that I also installed while I had everything apart.
whowa004 (11-12-2020)
I mounted my rear camera in the same place, and discovered one issue with that position. If the camera has white illumination LEDs on it, you'll discover that in the dark they reflect off the glass and you can't see anything.
I solved the problem by taping over the LEDs and installing lights attached to my roofrack. They're powered by the right rear tail light, and switched via a relay using the reverse lights as the signal. That means that they only come on in reverse when the tail lights are on.
I have a BlackVue dual camera set up in my D2 (and our cars). Won't drive without them.
Like the BlackVue design for being small and barely noticeable. The status LED lights can be configured for on or off. The rear camera LED is very discret and I like having it on while driving to let me know the system is working. I have it disabled in parking mode to not draw unwanted attention.
Did the same thing with running the cord between the cameras while the headliner was out. In our cars, I've run the wire along the headliner and pillars on the passenger side of the cars. You can tuck the cord away easy enough with some plastic interior trim tools.
Why I had my headliner out to fix the sunroof leaks, I ran the wires for a dual-camera dash cam, Rexing V1P Pro.
What product did you use?
Just a can or black spray paint for plastic.
I did first hit it with a plastic primer spray: https://www.amazon.com/Dupli-Color-C...3491683&sr=8-3
Thank you for your reply. Your backup housing looks great.
Discorama
09-12-2020 01:03 PM
ThatRealtorGuy
02-01-2019 02:29 PM
Doug18
09-22-2014 11:39 PM
