Easy question, but i cant figure it out
Sorry I need to edit what I said above. There is a radiator temp sensor in the radiator and there is a coolant temp sensor in the manifold. The sensor in the manifold has 2 very small tabs that you can pry with a small flat head to pull out the plug, then you can unscrew it.
The sensor in the radiator just has a clip you pop off, then pull off the plug, and unscrew the sensor with a wrench
Coolant sensor.pdf
Radiator Sensor.pdf
Coolant sensor.pdf
Radiator Sensor.pdf
My guess is you are having trouble unplugging the temp sensor for the SAI in the radiator. Its a pretty standard plug connection. Heres a link showing the sensor: http://www.roverparts.com/Parts/ERR2081.cfm
Just for future reference: the connection is held together by this clip (which you cant really see from the top). It will most likely go flying across the garage...
