EGR Valve O2 sensor relation
I had read this thread before the other one so no, I was not sure on what you meant.
But like Nitetrain said, a bad/clogged SAI could set off a O2 code I suppose.
The SAI works like a black smiths bellows, it forces air into the cats to heat them up faster to reduce emissions.
I do not know if a non SAI and a SAI truck use the same O2's or not.
