Electric Aux fan testing
Old Oct 21, 2019 | 07:52 AM
Micmac's Avatar
Default Electric Aux fan testing
Greetings,
This is a question about electric aux fan testing. Not the Viscous fan as it works and test as it should. Prior to recently installing a 180 Tstat (old one was bad) I saw coolant temp momentarily at 220F. The electric fan did not come on. The research I’ve read that coolant temp above 210 is one of the triggers for the aux electric fan. This is a new fan, 40a fuse not blown but replaced, relay replaced, fan jumped direct to the battery to confirm it works. The question I have is with current cooler temps is there a way that the logic of the fan can be tested for operation? Also what Is the coolant temp sensor for this? Does it get it from the ECM?
Old Oct 21, 2019 | 11:05 AM
Jason Feuerstein's Avatar
Page 4-10 of the RAVE manual says the switching point is 212F.
The logic is laid out in page 4.90 of the Electrical Library. It looks fairly simple; I would check your wiring to see if there's an open circuit.
Old Oct 21, 2019 | 05:51 PM
Micmac's Avatar
so as luck would have it it warmed up
enough in my area that I was able to confirm that the aux fan is working now. Must have been the relay or the fuse.
thanks for the info from the RAVE manual.
Old Oct 22, 2019 | 05:57 PM
Big Jim Swade's Avatar
Does it come on when you turn on the AC and the vehicle is stopped?
Old Oct 22, 2019 | 07:19 PM
Micmac's Avatar
Yes the ac was on and the vehicle stopped
Old Oct 23, 2019 | 10:40 AM
If the electric radiator fan is coming on when you switch on the AC, then it's not the fan.
zuke
Jul 4, 2017 06:28 PM
David A
Aug 19, 2010 08:51 AM
Eak69
Apr 6, 2010 04:50 PM
03discoman
Feb 22, 2010 08:12 AM
TXSALTY
Jul 6, 2009 11:30 AM
