Replacement hose
Old Jan 21, 2015 | 06:29 PM
Zonk872's Avatar
Default Replacement hose
Installed a new alternator... did not notice the bottom of the top radiator hose (elbow) was in contact with the top of the alternator pulley. Took the truck for a test run after installing the alternator. It rubbed the bottom neck of the hose but did not cut it to the point of leaking. It is the original hose. I have 58k miles on my 03' D2.
Question- can I get a elbow locally at a auto store instead of buying and waiting for the whole top set that is sold by the vendors? How thick is the hose inside dimension (diameter)? I don't want to disconnect it if possible.
Thanks
Old Jan 21, 2015 | 07:14 PM
OverRover's Avatar
You can use Dayco 70854 and any Advance Auto will have it for about $12. Just cut to fit.
More Information for DAYCO 70854
Old Jan 21, 2015 | 08:39 PM
Zonk872's Avatar
Thanks- worked like a charm!
Old Jan 22, 2015 | 06:10 AM
stb616's Avatar
I wish all these sort of cross over parts could be made into a list and made as a on sticky. Its such valuable info to have, especially as these get older
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
NhudeST
Apr 26, 2010 06:09 PM
deleon_daniel@sbcglobal.net
Apr 12, 2010 07:34 AM
bklahl
Feb 27, 2009 02:35 PM
