Electrical Issue
Old Feb 5, 2013 | 07:51 PM
jafir's Avatar
Fuse boxes do go bad on older D2, but I'd look at the crank sensor first.
Old Feb 5, 2013 | 08:52 PM
FlyingZebra34's Avatar
Would the fuse box prevent the vehicle from turning on?
Old Feb 5, 2013 | 09:01 PM
If the fuse box connections on the back are toast, then yes. Time for breaking out the RAVE.
Old Feb 5, 2013 | 11:57 PM
Alright, new one is on the way, hopefully it will resolve the issue.
On a side note is there lots of soldering involved or is it a plug and play type unit?
Old Feb 6, 2013 | 12:20 AM
Please see attached. Be sure every nut and spacer goes back on exactly like it came off or it still won't crank. Plug in and let it hang down to remount. Just a plug in connctor, no soldering.
File Type: pdf
Old Feb 6, 2013 | 01:08 AM
Uh, ok theres 2 issues with the rover, based off what I can see and the check engine codes, I think its the crank sensor, but the dealership thinks it's the fuse box.
Old Feb 6, 2013 | 08:18 AM
The fuse box can have all sorts of electrical gremlins lurking. It has relays and such built in, so it is part "module" as well. Also built to plug in a replacement.
Old Feb 6, 2013 | 01:30 PM
jfall's Avatar
I would replace the alternator.
It may be overcharging.
I bet your battery is fried from overcharge and I would replace the alternator and the battery.
actually I would do this:
1) Pull terminals from batter and clean them.
2) Replace the battery.
3) Replace the alternator.
3a) Check air conditioning compressor connection. Put an ohm meter across A/C clutch and check for low resistance or short.
4) Clear the codes.
5) run and check for new codes.
Your codes are:
Engine Code: p1536
Land Rover Engine Code: P1536 = Air conditioning compressor request range/performance ATC compressor clutch relay open circuit.
Click to Process more Land Rover Engine Codes here
Engine Code: p0560
Land Rover Engine Code: P0560 = System Voltage Malfunction
Old Feb 6, 2013 | 01:31 PM
jfall's Avatar
Whoa
Actually, you need to find and test the air conditioning clutch relay..
Looks like the ECU thinks the relay is open or shorted.
Old Feb 6, 2013 | 04:24 PM
Where is the AC clutch relay ? The used fuse block is in the mail but I guess I can wait to install it until I know that everything is ok.
