Electrical issues!
Old Aug 19, 2009 | 02:31 PM
james2009's Avatar
8th Gear
Default Electrical issues!
I am a first time Discovery owner. So far, so good. However I did notice two things that seemed odd and would appreciate any help! First, my interior light only comes on (when door opens) when it rains. When it is not raining, it does not work. I have replaced the bulbs and had a good laugh when I discovered this.
Also- while driving on highway, my ABS light and traction control came on. After stopping for gas, it went off and has not come on since. Are these two somehow related?
Thanks for any help. (It is a 2000 Diso II).
Old Aug 19, 2009 | 04:40 PM
Rover Chris's Avatar
the ABS could be due to a bump in the road (did you notice any potholes or anything before it came on?) the system will detect a rough road (and think your offroading) and then disable itself (at least thats how the D1 is I believe the D2 is the same as that goes)
as for your interior light does this happen with all the doors or is it just one? could be a bad pin switch, may take some grease and lube up all the switches a bit.
MoNtErover
Sep 24, 2008 08:08 AM
jobob307
Jul 2, 2008 07:26 PM
95raingerowver
Feb 19, 2008 07:28 AM
dustin309685
Nov 18, 2006 07:45 PM
russ00001
Aug 6, 2006 03:54 PM
