electrical Q.
Old May 5, 2016 | 02:28 PM
pilsner's Avatar
Default electrical Q.
So I searched the threads on here first and didnt find the answer to my question.
What would cause a sudden stoppage of the following:
Turn signals all around (when I use the signal it will flash the directional arrow ONCE on the display then nothing... no clicks, no lights flashing on vehicle. Just nothing.)
Both sun roofs do not respond to buttons - no movement at all.
Hazard lights dont work ( I ASSUME this is tied to the turn signal light issue above...)
Windshield wipers dont work.
Check engine light is on but it is all O2 sensor stuff (I cut out my catalytic converter a while back so it stays on at this point) and is giving no electrical codes.
No other issues.
So where do I start? I noticed that I have one rear turn light bulb that is burnt out BTW - will replace on next trip into town. Fuses?
Has anyone had this issue before?
Thanks guys and gals!
-Pilsner
American 2000 D2 with V-8 and 170K (rebuilt engine 3k miles ago).
Old May 5, 2016 | 05:37 PM
Alex_M's Avatar
If its not working at all more than one click, then the front and rear bulbs are dead.
Sun roof computer maybe? I'm only works sometimes and its the little controller.
Wiper motor? Fuse? Check the fuses first obviously. I replaced a wiper motor because of a bad fuse once.
Get some 90 degree bend O2 spacers on eBay. Like $10-$15 each. M18 thread size. That will clear the cat code.
Old May 6, 2016 | 06:44 AM
cappedup's Avatar
On click only suggests relay to me. It's clicking one way, but won't throw it the other.
But with your combination of issues, I wonder if they are all linked. Issue inside the same fuse box or something.
JRdisco1
Jan 4, 2006 11:31 PM
JohnJaquaIII
Aug 15, 2005 12:47 AM
sclarkie
Aug 11, 2005 02:20 PM
My98disco
Aug 4, 2005 01:21 AM
dp_roberson
Apr 29, 2005 12:24 AM
