Electrical and starting question.
Old Nov 8, 2012 | 05:33 PM
ExpeditionMedic's Avatar
Default Electrical and starting question.
Hello,
First question. When I turn the headlight switch to parking lights, everything works (parking lights, taillights, dash lights). When I turn the switch to the headlight position, the headlights work, but I lose my dash lights and rear lights. Any thoughts? The turn signals works fine. Worn out stem, bad ground, replace the turn signal/headlight stem?
Second question. I'm getting spark, all fuses check out, but while the engine turns over with no problem (brand new Optima yellow top), all of a sudden she will not start. I'm guessing the CPS dumped on me? (FYI, since I have owned her, she has started right up and runs very nice, took a 6 mile test drive yesterday after I finished the lift and put the new tires on, fired right up ran perfectly. An hour later, no joy.)
Here is a run down on what I have done since I purchased my disco last month.
1999 Discovery II
151,000 miles
3" OME Lift
OME front steering stabilizer
275/65 18 DuraTrac's
HD greeseable front drive shaft
Optima Yellow Top Battery
Kenwood Reciever
Lowrance HDS5 mounted on the dash
Falconworks shuttle valve replacement in ABS modulator
New front windshield
New spark plugs
K&N air filter
Tactical Rovers front winch bumper (will order monday)
New valve cover gaskets (install next week)
Engine block heater (will order monday)
Old Nov 8, 2012 | 06:06 PM
lr2001silver's Avatar
Banned
Yes could be master switch failed and on your no start issue could be your fuel pump quit. Si ce you have spark next you need fuel so check and post back. Welcome to the forum!
Old Nov 8, 2012 | 06:07 PM
Banned
Where are that your needing a block heater? And damn you put alot in it this month lets see some pictures!
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
Boiserover
Apr 3, 2013 01:56 PM
mherson
Oct 17, 2010 04:05 PM
baysiderover
Oct 6, 2006 06:58 PM
FORDSTANGER
Nov 6, 2005 10:00 AM
