Eletric Problem in 2002 Disco
Old Mar 4, 2009 | 11:15 AM
NewLandroverlover77's Avatar
3rd Gear
Default Eletric Problem in 2002 Disco
Ok I just bought a 02 Disco about a week ago .Now the the truck drives beautiful no problems at all . But it seems to b a problem with the eletric . Like the radio and ac keeps turn on and off . And then I have to stop the car and then turn it off and on . And then turn it on . Now I am not understanding y it does that . Does anyone have any answers ?
Also the heat is not getting hot when sitting it only gets hot when the car is moving. I am guessing thats the heat from the engine thoe .
Old Mar 4, 2009 | 11:50 AM
AK Rover's Avatar
No ideas about your electrical problems but for your heat problem check your coolant level. If it is low you won't get adequate circulation at idle to get heat. You may also have to bleed the cooling system.
Old Mar 4, 2009 | 12:25 PM
khuds308's Avatar
does it shut off when you go over bumps?
Old Mar 4, 2009 | 12:52 PM
Rover Chris's Avatar
yes I would clean and possibly re-tap the ground in the drivers kick panel
Old Mar 4, 2009 | 01:55 PM
3rd Gear
In the drivers kick pannel ? Ok will do so . And also can I take it to like a auto shop and get the coolant flushed ?
Old Mar 4, 2009 | 02:00 PM
not sure on a D2 but my D1 says not to flush the coolant system. not sure why but it should just need to be topped off,bled, and pressure tested, of course I may be wrong on this
Old Mar 4, 2009 | 02:58 PM
3rd Gear
Yea this guy in a other forum tld me the d2s u have to drain emm and i called a dealer and they say the same so .
Old Mar 4, 2009 | 03:08 PM
drain it or bleed it? there is a difference if there is a plastic screw on top of the radiator it needs to be bled (meaning the air has to be released), if it is on the bottom of the radiator it has to be drained, I would think the only time it should be drained is if you are removing parts or the coolant is no good.
I am sure Mike will jump in on this one soon and he should know for sure
dillhole
Oct 14, 2013 08:49 AM
rcglfr
Jul 2, 2013 02:10 PM
washington2133
Freelander
Sep 30, 2008 06:24 PM
johnkubik
May 1, 2008 02:55 PM
jonnymcd
Sep 12, 2006 02:27 PM
